port engine stalling, 350 mag carb question >
Old 06-29-2004 | 08:08 AM
BajaRunner's Avatar
Default port engine stalling, 350 mag carb question
My port engine, 87 model 350 mag with carb (quadrajet) is stalling. Ive changed the spark plugs, wires, cap and rotor, set the timing, still stalling. Im no carb expert, so i need help. it (normally) idles around 700. It started stalling out, so i turned up the idle to 1100. it still stalls out. would it be in the idle jet. is that something you can take out, spray out with some carb cleaner and be all good?
btw, Its an alpha outdrive and i am 100% its not the shift interrupter.
help.
BajaRunner is offline
Old 06-29-2004 | 08:23 AM
Default Re: port engine stalling, 350 mag carb question
? does this happen in neu position or when you put it in gear?
sonic28 is offline
Old 06-29-2004 | 08:25 AM
BajaRunner's Avatar
it idles at 1100, no problems, when it drops in, it kills it.
Old 06-29-2004 | 08:35 AM
cuda's Avatar
Sure sounds like the shift interrupter to me. What happens is the lower shift cable gets sticky and doesn't return to the run position quickly enough to keep the engine running. Even checking the switch won't tell you that.
cuda is offline
Old 06-29-2004 | 08:47 AM
Iggy's Avatar
I thought the interrupter worked only when shifting out of gear into neutral? Power needs to be cut so engagement dogs would release.
Thought it wasn't needed when engaging forward or reverse?
Anyhow, I'd look at the interrupter switch first then cable operation.
Iggy is offline
Old 06-29-2004 | 08:48 AM
BajaRunner's Avatar
i replaced the lower shift cable, about a year ago, no problems whatsoever until now. it does it only after it warms up.
Old 06-29-2004 | 10:33 AM
Bypass The Switch By Connecting Both Terminals Together Then Try To Shift. Note Keep The Rpm Down.if It Doesn't Stall Replace The Switch.note Again Once In Forward Shut The Motor Down So You Wont Do Any Damage.
Also You Might Want To Take The Switch From Your Other Motor And Try It That Way. Good Luck
sonic28 is offline
Old 06-29-2004 | 10:49 AM
BajaRunner's Avatar
ok, more info is coming back to me, havent drove in a couple weeks. it doesnt always stall when going into gear, it can go into gear, and most of the time does, be idling in gear and die. when its in gear and idling, its usually around 700 rpms, then it dies. again once its warm.
Old 06-29-2004 | 10:53 AM
mr_velocity's Avatar
Sounds like a problem in the idle circuit since when it's cold you have the choke to get you more gas and when at 1100 rpm you're off the idle circuit. Time to pull the carb apart....I need to do two Dominators this weekend.
mr_velocity is offline
Ranman
03-22-2016 10:20 AM
zgoo
22
05-07-2007 10:54 AM
2 Trick Rick
6
06-20-2006 07:09 AM
ldweber51
4
06-07-2003 08:14 PM
