How to tighten Marine Machine Throttles? >
Old 07-01-2004 | 06:39 AM
BillR's Avatar
OSO Moderator
Lightbulb How to tighten Marine Machine Throttles?
My new boat has marine machine throttles and they are very loose. I want to add some friction so they do flop to idle if I remove my hands from them. They do not have the set screw inside (like Livorsi).
How can I tight these up?
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 07-01-2004 | 10:09 AM
P Offshore's Avatar
Default Re: How to tighten Marine Machine Throttles?
There are 3 bolts that hold the entire assy together, if you tighten those the levers all get more "squeeze" and thereby tighten the friction. I don't know how to tighten just one at a time or if it is even possible.
P Offshore is offline
Old 07-02-2004 | 08:53 AM
GLH's Avatar
GLH
I have Latham on mine and they come back to idle if I let them go.
The spring on ours are located at the throttle linkage at the attachement by the blower. If you take the spring out they will not return by themselves anymore.
This is on Merc 600SC's.
Right there.
Attached Thumbnails How to tighten Marine Machine Throttles?-throttle-spring.jpg
GLH is offline
Old 07-02-2004 | 11:13 AM
dlbCheckmate's Avatar
Yes, but if you remove the spring then what happens if your cable should break or fall off ? The return spring is on the unit for this reason, so if you have a mechanical failure you would not be running with no throttle control. ( kinda like when the throttle bores freeze up on a snowmobile ) I personally preffer the friction method. My 2 cents.
dlbCheckmate is offline
Old 07-02-2004 | 11:14 AM
Oh, nice motors by the way !!
Old 07-02-2004 | 11:36 AM
Mine have plastic friction buttons on each lever. You could make some buttons that are slightly thicker: I think.
Due
Dueclaws is offline
Old 07-02-2004 | 12:29 PM
2112's Avatar
Angry Re: How to tighten Marine Machine Throttles?
What you are describing is a design flaw that Marine Machine knows about. They changed their design about a year ago. They will not do anything to help you. How do I know? I custom order a brand new set and did not install them right away. When I went to install them, I had the same problem. If you tightened the center screw (big phillips head screw in that acts as the center shaft) You could tighten them but how much differed drastically from one throttle to the other.
I returned mine to MM for and adjustment. They were brand new, never installed. They tightned and returned. "we changed the design to fix that" "You need to buy a new set if you don't like it". wow. Yes they were a year old but still new in the box. All for $1600!
They are improved in a tighter setting but still not equal in resistance to movement.
Next time; Latham
2112 is offline
Old 07-02-2004 | 04:49 PM
BillR's Avatar
OSO Moderator
I called MM and they offered to help me. I was told to send them in and they would get it right.
Now exactly what "right" means, I don't know.
They said on the phone they made a mistake with these older throttles.
I'll send them in about 2 weeks and we'll see what they do to them.
Next time; Latham
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 07-02-2004 | 04:51 PM
BillR's Avatar
OSO Moderator
I only saw 1 big phillips screw and it was on the port side on the throttles.
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
zum.offshore.Malta
01-14-2011 07:22 AM
BryanTuvell
11-13-2006 07:13 PM
BajaBennett
05-19-2005 10:46 PM
stecz20
12-14-2003 11:12 PM
