how do these plugs look? >
Old 07-08-2004 | 01:58 PM
wwwTOPDJcom's Avatar
Default how do these plugs look?
502 efi 22hours
wwwTOPDJcom is offline
Old 07-08-2004 | 02:16 PM
Reed Jensen's Avatar
Default Re: how do these plugs look?
They look good to me.... insulator is the right color... a little sooty on the base...which tells me that it isn't lean... maybe a little on the rich .. which is ok.... I'd put in a fresh set and you are good to go...
Reed Jensen is offline
Old 07-08-2004 | 02:41 PM
transom has a slight film of soot, new plugs are in they may be a little sooty
from when the T stat went bad and stayed open about 11 hours ago
so far at 9 hours I got a ect cold temp code whiched turned out to be a bad T stat
and at 22 hours I got a High temp low oil pressure stored code
which looks like it was the impeller and had 3 blades missing a small piece
which in turn burned up one of my exhuast hoses. Thats one of the reasons I pulled the plugs to make sure nothing was running lean.
I also put a diff piece of hose on the stainless marine riser it looked kinked
Old 07-08-2004 | 02:53 PM
Hydrocruiser's Avatar
Go with NGK's. They idle better.
Hydrocruiser is offline
robyw1's Avatar
Looking good, the black soot is normal and to me doesn't even look particularly rich. If you want to get pickey I can say that that was a horrible job of indexing but you probably didn't bother
Roby
robyw1 is offline
nitrotommy
0
09-18-2007 07:12 AM
eliminatethis
2
06-21-2006 10:25 AM
DMAX
5
05-19-2006 04:37 PM
wwwTOPDJcom
05-23-2002 10:58 PM
