Pro Max 300's, good or bad?? >
Old 07-08-2004 | 04:49 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
Default Pro Max 300's, good or bad??
A friend of mine is looking at a 30ft cat w/ 02 300 Pro Max's. Are these motors reliable? What is your opinion?
mcraymond3 is offline
Old 07-08-2004 | 05:32 PM
Default Re: Pro Max 300's, good or bad??
My boss has 2 on his cigarette and has had to do a bunch of stuff to them. Right now he is redoing a lower unit on one. And he does baby his stuff.
BobbyB is offline
Old 07-08-2004 | 07:20 PM
I'e had a few issues with the lowers also, turns out the shift shaft seal likes to pop out and allow sea water to enter the case. I went and had the lowers with the seal customized so the seal wont push out. Other then that they run like bandits, but remember they are racing motors and things will happen on motors being pushed to those tolerences. If you think those are moody try the 250x racing, and then you'll know why guys who run these have a mechanic on call.
Donzi Corleone is offline
Old 07-08-2004 | 07:43 PM
frequentflyer's Avatar
I haven't had problems with my 98's other than my lower units. The 02's however are a totally different animal. They changed in 2001 to the X's. More HP and more problems from what I have heard.
frequentflyer is offline
Old 07-08-2004 | 07:44 PM
In retrospect though..... What performance boat is low maintenance? or doesn't break down... Ya wanna play, ya gotta pay...
Old 07-08-2004 | 07:51 PM
RLW
Amen to that!
RLW is offline
Old 07-08-2004 | 07:53 PM
dreamboater's Avatar
I guess you here different things about everything. A guy local on the Potomac had a 26 AO cat w/twin 300 pro max's. This guy is hard on everything. He had over 400 hours, and according to a computer reading done 80% of the motors life was over 5000 rpm, the compression test also showed no signs of needing to be rebuilt. I have heard the 300 pro max's are a lot more reliable than the 300x motors but they are making 25-40 less HP.
dreamboater is offline
Old 07-09-2004 | 07:04 AM
All my issues have been with the lowers not the motors.
Old 07-09-2004 | 09:47 AM
Yeah but that can get expensive. Believe me I have had to rebuild both of them. I do have to agree though that my problems have only been with the lowers too... And I have over 250 hrs on mine. Still going strong. Knock on wood...
Old 07-09-2004 | 01:56 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
Thanks for all the input.
