What Props do I need?
come on RJ, the guy is asking a SERIOUS question. Don't sell those props here.
I would contact either Throttle -Up or Houston Propeller and ask their advice.
They are advertisers here. Go to Marine Link on top of page.
Yes, the Bravo 1 props will fit the TRS drive with no modifications.
Most of the boats with the TRS drives work well with the Mirage or Mirage plus. The Mirage is no longer available and has been replaced with the Mirage plus. The Bravo 1 is an option as well but you will most likely lose a couple mph on the top but pick up a couple mph in the mid range.
Matt
Matt
You can find a pair of used Mirage props, since many have switched to four blades. You don't need four blades with the drive as deep as it likely is on that boat. If you have enough power, the 25 Mirage is hard to beat.
raiseyourdrive
09-15-2004 08:23 AM
