3" Trailer Winch Straps
Old 07-12-2004 | 07:49 PM
Default 3" Trailer Winch Straps
Does anyone know where to get 3" wide winch straps. Everyone carries 2" but I have been unable to locate anyone with 3".
353guy is offline
Old 07-12-2004 | 08:07 PM
SHARKEY-IMAGES's Avatar
OSO Content Provider
Commercial Members
Default Re: 3" Trailer Winch Straps
Home Depot perhaps?
I know I picked up a set from there. Now whether they were 2 inch or 3 I don't remember....
www.TimSharkey.com/
Digital Photography & Video one BYTE at a time !
SHARKEY-IMAGES is offline
Had the same issue with my trailer a few years ago. Couldn't find them anywhere. Here's what worked just the nuts. In the Overtons catalog, there is a section for boat hoists/lifts. They had a diagram of two 3 inch wide straps to go under and lift small boats. At each end of the strap was a triangle shaped hook. I cut off the one hook. That end attached to the winch pulley without any other modifications. Obviously the other end attaches to the boat. To do so, I went to Home Depot and found the correct hook that I attached to the triangle shaped hook at the end of the winch strap. I believe the strap is 10 ft long. Has worked fine for my 10,000 # boat.As you know, those winch straps don't last long sitting out in the sun,etc. I hope this helps!--Lou
Lmarth is offline
Old 07-12-2004 | 09:49 PM
buck183's Avatar
Might give Warparty36 a holler. He may be able to fix you up.
Buck
buck183 is offline
Old 07-12-2004 | 09:53 PM
stecz20's Avatar
i picked some up at home depot the other day.
stecz20 is offline
Old 07-12-2004 | 11:26 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
He is talking about the winch strap that goes onto your bow stop winch.
Try a truck stop.
Sydwayz is offline
Old 07-13-2004 | 05:29 AM
BURNSMAZZ's Avatar
Call Loadmaster Trailer in Port Clinton Ohio they can hook you up.
BURNSMAZZ is offline
Old 07-13-2004 | 07:53 AM
WARPARTY36's Avatar
Drive to arrive alive!!!
I have 1" to 12" nylon and polyester webbing. Send me an e-mail with the length and hook style and I will give you a price. The top picture shows a 1",2",3",8" sitting on a 24" lifting strap.
[email protected]
Attached Thumbnails 3" Trailer Winch Straps-24-inch-slingsm.jpg   3" Trailer Winch Straps-dsc00028sm.jpg
WARPARTY36 is offline
Old 07-13-2004 | 10:28 AM
Warparth36--Very impressive!--Lou
Lmarth is offline
Old 07-13-2004 | 08:20 PM
Warparty - I also sent you an email but here is what I need;
I have a 353 Formula that's about 10,000 pounds and this is for the trailer winch. I need a 3" wide strap and 15' to 20' in length. It need to hook to the bow eye so I need some type of metal hook on that end. The other end has a loop sewn into it that a 3 1/4 by 5/16 bolt is fed through. Let me know if this is something you can do.
353guy is offline
