Doggy Cat
Old 07-14-2004 | 08:42 PM
Angry Doggy Cat
I have a 2001 28 Profile Cat. 500 EFI, extension box, that I just bought. Running a 28 four blade with 60 gallons of gas. It does 72 gps at 4400 rpms. Does anyone have an idea what could be wrong. Profile says I should be doing 80 plus at 5300rpms but does not offer any suggestions.
Bad Kittee is offline
Old 07-14-2004 | 09:04 PM
Default Re: Doggy Cat
Not a cat man myself, but It sounds like if you get those rpms up to what Profile is telling you, the speed should be in that vicinity.
Different prop ??
Tune up ??
Trim it up more ??
Jenny Craig ??
otis311 is offline
Old 07-14-2004 | 09:16 PM
X-Rated30's Avatar
I have a friend that had the same boat w/o the extension box. Did 80+ any day of the week. (I love the boat.) I have to say that sounds like a motor problem. I don't think the prop sounds too big, and efen if they really f***ed up installing the box, it shouldn't cause this.
I'll try to remember to ask him what prop he was running.
X-Rated30 is offline
Old 07-14-2004 | 10:15 PM
sound like a sour motor 28p on a small cat sounds ok
compresion and leakdown needs to be checked?
dreamer is offline
Old 07-15-2004 | 07:48 AM
Airpacker's Avatar
What gear ratio in the drive? A 28 on 136 gears and the 500 wont really pull it. Is it a labbed 28? If its is and the gears are 150, then I am afraid you prolly have a sick motor. A 25 daytona or Talon with a 500efi will run just around 80 to 83 at 5000 to 5200 rpm with a 150 gear and 28 bravo or a 136 gear and a 26 bravo so you should be right in that area if all is working correctly.
Airpacker is offline
Old 07-15-2004 | 10:36 PM
X-Rated30's Avatar
Checked with my friend -- He was running a 25p four blade. Keep us posted.
Old 07-19-2004 | 09:12 AM
Thanks everyone. Seems like I have my work cut out for me!
Old 07-19-2004 | 09:18 AM
ONESICKGLADIATOR's Avatar
45 Lip Ship / 900 Zul's
you could have to much tab in the water
Rick osg
ONESICKGLADIATOR is offline
baronmarine
Saber
10
06-28-2007 10:40 PM
Bad Kittee
5
07-16-2004 04:01 PM
