Gaffrig Shifter adjustment???
You should be able to adjust it with an allen wrench from the top side. look thru the black rubber boot at the base of the handle for the tension adjusting set screw. It is basically a set screw which presses a nylon pad against the shaft. As the nylon wears, you have to tighten the set screw. The nylon pad can be replaced if it is worn out completely without disassembly of the unit.
SHAKEN Not Stirred
29
06-26-2003 01:05 PM
