How much does added weight effect your speed ? >
Old 07-21-2004 | 05:05 PM
Jamie B.'s Avatar
Warped & Twisted Member
Default How much does added weight effect your speed ?
I have in my head from somewhere that for every 200-225 pounds that you lose 2 mph. What I dont remember is at what weight level that applies to ?
200 pounds effects a 5000 pound boat moreso than a 10,000 pound boat if they both run the same top speed, right ? Can anyone explain or is there a formula that can explain how much weight effects things in a boat ?
Thanks in advance.
Jamie B. is offline
Old 07-21-2004 | 05:10 PM
Waterfoul's Avatar
Gone Fishin'
Default Re: How much does added weight effect your speed ?
Actually, I don't see anything near a 2 mph difference in my boat's speed whether I'm alone or have 2-3 others with me. Granted, most of my friends weigh less than 200 lbs. 24 Baja Outlaw, currently without power though....
Waterfoul is offline
Old 07-21-2004 | 05:12 PM
hp500efi's Avatar
Member #9
Mike, you forgot to mention that you drag an anchor all the time so that probably has more to do with it than the 2 added guys . . . .Bwahhhhahah
Member of the Liquid Jungle
hp500efi is offline
Old 07-21-2004 | 05:24 PM
Indy's Avatar
Member #154
I suspect that air temperature and humidity has more effect than a few hundred pounds, at least in my experience in a single 28' boat. I've had one passenger and light fuel in hot/humid days, and I was faster with 3 friends & full fuel on a cooler fall day. I know this doesn't answer your question, but other factors come in to play also.
Indy is offline
bouyhunter's Avatar
sure, - without power I imagine that 24 outlaw would go the same speed with 12 people...ZERO.
bouyhunter is offline
Old 07-21-2004 | 05:26 PM
Waterfoul's Avatar
Gone Fishin'
OK, OK, OK.... I'm talking about WHEN my boat ran. Sheesh!!
Old 07-21-2004 | 05:30 PM
Jamie B.'s Avatar
I agree and understand that temp / humidity / water conditions / etc can and do effect things as well.
I'm wanting to know if there is a formula that determines how weight effects things when all other things are equal or are accounted for.
Thanks guys.
Jamie B. is offline
Old 07-21-2004 | 05:31 PM
Jamie B.'s Avatar
haha . . rough crowd !
Jamie B. is offline
Old 07-21-2004 | 05:38 PM
bouyhunter's Avatar
come on now....
I couldn't let that go un-noticed.
If I wouldn't have said it, someone else would have
Old 07-21-2004 | 05:44 PM
44MTI's Avatar
Jamie'
I think it depeends on the type of hull as well as the brand. In my 42 fountains I never saw much if any difference. However in my can there is an noticeable difference. I think the formula for it is 1mph for ever 200lbs and the nortech is similiar.
44MTI is offline
