Would these blocks make good marine engines? >
Old 07-22-2004 | 04:34 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
Default Would these blocks make good marine engines?
I have a guy locally that wants to build me a pair of motors out of these aluminum blocks. I have been told that innovation built these motors originally for the government. Here are the specs I know:
660 cubic inch
J&E pistons
5.1 stroke
8:1 compression
crower billet crank
supposed to make 793 ft. lbs. of torque at 3800 rpm and approx. 750hp.
what do you guys think? Would aluminum blocks be a problem?
thanks for the input.
Attached Thumbnails Would these blocks make good marine engines?-innovation-motor-003.jpg   Would these blocks make good marine engines?-innovation-motor-001.jpg   Would these blocks make good marine engines?-innovation-motor-004.jpg
mcraymond3 is offline
Old 07-22-2004 | 08:46 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
Default Re: Would these blocks make good marine engines?
Help, opinions please.
Old 07-22-2004 | 08:58 PM
robyw1's Avatar
Can you flip it over and snap a pic of the top
Roby
robyw1 is offline
Old 07-22-2004 | 09:28 PM
phughes69's Avatar
I know we built a all alumin bbc for a drag race car. It was a Dart block 474 CID I know that it had to fully warm up (160 deg) before it could be driven. I'm not sure how cold lake water would affect the cylinder bores but I do know that the bores do move around QUITE A BIT when the engine is heating up. Also how much does he want to build it for? Seems with that much cubic inch is should be up around the 1000 HP mark for a NA motor.
phughes69 is offline
Old 07-22-2004 | 09:59 PM
I would check out the availability of replacement parts, such as bearing, pistons, rings,etc. Make sure parts are still available at reasonable cost before getting into these. Also, what head bolt pattern and heads will fit on these. Are they a standard tall deck or something special that will require custom intake manifold, etc. Just stay away from obsolete pieces that cannot be rebuilt or have parts replaced easily.
Just my thoughts,
Raylar
Raylar is offline
Old 07-23-2004 | 08:34 AM
I wouldn't touch it for free. Stay with what you know works. Minimize the surprises.
SmallPP is offline
Old 07-23-2004 | 08:40 AM
PatriYacht's Avatar
Is that a Donovan block? I 've seen a few Innovation big inch aluminum engines and they always seem to run well. It's like a World or Dart block.
PatriYacht is offline
Old 07-23-2004 | 08:52 AM
robyw1's Avatar
That is what I thought it was but I wanted to see the top of it. That block appears to be sleeved as well. If that is the case the Donovans are for the most part drag race blocks and their water passages just don't cool well causing premature cylinder wear.
robyw1 is offline
Old 07-23-2004 | 05:24 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
It is a Donovan block. He will build for 12,650 per side. Thanks for all the input. I am really just looking for something around 750 hp n/a and really reliable. Any ideas?
ratman
09-13-2006 07:33 AM
Wateronthebrain
08-12-2004 11:06 AM
packinair
10-05-2003 07:23 PM
klmken
03-03-2003 05:47 PM
Bo Knows
07-06-2002 09:46 AM
