what prop should I use ? >
Old 07-23-2004 | 06:01 PM
MiamiVice's Avatar
Default what prop should I use ?
I want to try new set of props for my boat. 1995 32' Fountain Fever w/ 502 Mag EFI and Bravo 1 Drives. What do you guys think would give me the best top end speed and slow speed handling.
MiamiVice is offline
Old 07-24-2004 | 09:53 AM
throttleup's Avatar
Default Re: what prop should I use ?
For top end the Quad IV would be best and for mid range/ minimum planning speed the Bravo 1 would be best. Unfortunatley what works best on the top end usually doesn't work best at low to mid range speeds.
Matt
throttleup is offline
Old 07-24-2004 | 11:00 AM
Smitty's Avatar
I've got a buddy with a 1996 single step and 502's. He runs 26" Bravo 1 and sees 75 mph top end. Overall good performance. As Matt stated you have to give in one area to get something in another. There is no prop yet that will do everything perfect. Just like life, it is all a compromise !!!
Smitty is offline
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
