not getting rpms >
not getting rpms
not getting rpms
Old 07-23-2004 | 09:53 PM
not getting rpms
Had New 454 Ho's 420 Hp Engines Installed In My 42" Wellcraft And Not Getting The Rpms I Should. Was Running 51 Gps Mph At 4800 Rpms On Old Motors. New Motors Running Only 3500 Rpms Top End. Could Fuel Pumps Be A Problem. Noticed Mechanic Installed 2 New Electric Fuel Pumps. What Should I Be Running For Gpm Pumps And Presure For 454 Ho's. Everything Is New Out Of The Crate Not Rebuilds
electrical1 is offline
Old 07-24-2004 | 06:31 AM
Default Re: not getting rpms
I had one engine do that last year. The ignition module was bad,not advancing the timing. You should have full advance around 32-3500rpm, I think.Sounds like timing. Put a timing light on it. I dont think fuel would limit rpm like you describe. Does it pop or mis or just run out of steam at 3500?
HOTTZU98 is offline
Old 07-24-2004 | 04:54 PM
runs smooth just run out of steam no popping or missing. I'VE BEEN READING ALOT ABOUT ADVANCE TIMING ON OS BUT DON'T KNOW HOW TO CHECK IT. THE ONLY THING I KNOW IS HOW TO SET UP REGULAR TIMING.
Old 07-24-2004 | 09:33 PM
I had the same problem with a pair of 502"s The owner before had put two new electric pumps on and also fuel filters between the tank and pumps. I could only get 3800 out of them, moved the filters to between the pump and carbs, now no problem. It worked for me.
rasttus is offline
Old 07-28-2004 | 02:37 AM
Xx
Old 07-28-2004 | 11:04 PM
OkieTunnel's Avatar
What HP were the old motors and what props are you running?
OkieTunnel is offline
niceguy
9
05-08-2008 10:08 AM
Ken N
1
07-22-2007 12:51 AM
docmanrich37
7
03-16-2006 02:59 PM
electrical1
1
12-27-2003 11:22 PM
Ratchet
15
01-25-2003 10:39 AM
