Xr Drives
Old 07-27-2004 | 11:37 AM
scottsumrall's Avatar
Default Xr Drives
How Can Someone Tell The Diff. Of A Standard Bravo And An Xr. The Reason Is That The Drives Have Be Painted Red And They Do Have The Xr Stickers. The Drives Were Painted By Mercury.thanks
scottsumrall is offline
Old 07-27-2004 | 02:20 PM
Doller Offshore
Default Re: Xr Drives
larger or heavy duty u-joint assy.
Old 07-27-2004 | 04:06 PM
Those two statements are correct for the XR and XZ. The upper gears is what you need to look at. The SN will tell you unless someone is trying to pull the wool over your eyes.
BadDog is offline
Old 07-27-2004 | 05:04 PM
Mr Gadgets's Avatar
Charter Member #601
Pull the top covers and look for gears with big ole teeth... there are pics of them all over the net..
Mr Gadgets is offline
Old 07-27-2004 | 08:13 PM
RLW
www.go-fast.com/mercruiser_bravo_sterndrives.htm
Check out the site above for an explanation of Bravo Outdrive differences.
Thanks to Mbam for providing this information.
RLW is offline
Old 07-27-2004 | 10:25 PM
RJ1340's Avatar
Bravo, XR, ZR, IXR....they're all going to break on you, so what's the diff?
RJ1340 is offline
Old 07-28-2004 | 11:03 AM
P Offshore's Avatar
The carrier in the Xr, (looking behind the prop shaft) is blue all others are not.
P Offshore is offline
Old 07-29-2004 | 06:39 AM
GLH's Avatar
GLH
Beats sailing.
GLH is offline
Old 07-29-2004 | 09:49 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Not true. I have XZ drives, and mine are blue!
Sydwayz is offline
Old 07-29-2004 | 11:06 AM
Mr Gadgets's Avatar
Charter Member #601
Sailing is like being towed in after your drive breaks.. but I would rather get the tow..
