650 Dominators
Old 07-28-2004 | 11:40 AM
Rico's Avatar
Default 650 Dominators
Can any one tell me, good or bad about these? Might be buying a boat with them. Thanks
Rico is offline
Old 07-29-2004 | 04:00 AM
Default Re: 650 Dominators
You mean carbs??????
The smallest Dominator carb I have seen advertised anywhere is a 750cfm.
Griff is offline
Old 07-29-2004 | 08:04 AM
Strip Poker 388's Avatar
Rob
The small Dominator is a 750cfm. Most people bought them for looks.Race only style carb.Its a 2 circut carb . Most of the dominators are a 3 circut so you can tune the mid range. I ran the 8896-1 on my blower motors with good luck and power
750 --http://www.holley.com/HiOctn/ProdLine/Products/FMS/FMSC/0-80186-1.html
Here is the Holley link http://www.holley.com/HiOctn/ProdLin...MSC/Dmntr.html
P/N 0-80186-1 750 CFM Four Barrel
P/N 0-8082-1 1050 CFM Four Barrel, 1x4, 2-circuit metering
P/N 0-8896-1 1050 CFM Four Barrel, 1x4, 3-circuit metering
P/N 0-80586 1050 CFM Four Barrel, 2x4, 3-circuit metering
P/N 0-9375-1 1050 CFM Four Barrel, 2x4, 3-circuit metering
P/N 0-7320-1 1150 CFM Four Barrel, 1x4, 2-circuit metering
P/N 0-80556-1 1150 CFM Four Barrel, 1x4, 3-circuit metering
P/N 0-9377-1 1150 CFM Four Barrel, 2x4, 3-circuit metering
P/N 0-80532-1 1250 CFM Four Barrel, 1x4, 3-circuit metering
P/N 0-80533-1 1250 CFM Four Barrel, 2x4, 3-circuit metering
How To Calculate CFM:
Engine size (CID) x maximum RPM / 3456 = CFM
CFM @ 100% volumetric efficiency
Strip Poker 388 is offline
stormbauer
Swap Shop
26
01-24-2009 07:00 AM
2dogshumpen
4
08-22-2008 08:32 AM
shaun harrington
Wanted
7
07-09-2008 06:07 AM
2112
12
08-31-2005 01:49 PM
blown formula
7
10-21-2004 12:37 PM
