Compression #s, are they OK?
Procharged 502s with heads ported and 3 angle valve job. Not sure about compression. 8:?
Reason for testing is because exhaust manifold risers were leaking and surface rust was around exhaust valves. Pictured below is 1 valve that seems "off center", and also has the lowest compression.
Readings
155 155
163 156
145 162
155 157
These might be off by 1 or 2 lbs.
Readings
155 155
163 156
145 162
155 157
ANY TIME THESE ENGINES INGEST WATER AND YOU GET THAT TYPE OF CORROSION AROUND THE VALVES YOU SHOULD CONSIDER REPLACING THE VALVES AND REVALVE JOBING THE HEAD YOU GET PITTED VALVES AND SEATS AND YOUR COMP WILL VARRY BUT THE BIG CONCERN IS LOOSING A VALVE THATS NOTHING BUT TROUBLE. THE VALVE BEING OFFSET CAN BE A WORN VALVE GUIDE FROM CORROSION . LOOK AT THESE POSSIBILITIES CLOSELY YOU CAN MOST LIKELY HAVE A GOOD SHOP IN YOUR AREA HELP YOU GET BACK IN THE WATER QUICKLY. IF YOU CANT FIND ANYONE LOCAL THAT CAN HELP GIVE US A CALL AND ILL HELP ANYWAY I CAN LAZ MESA WWW.MESABALANCING.COM
Official OSO boat whore
You have a 20psi variance in pressure. I'd say the numbers were ok, if it wasn't for the one cylinder. Knowing the amount of rust you have in there, I'd pull the heads and replace all the valves.
Originally Posted by blue thunder
Valves get brittle from being very hot then quenched by rogue water. They can shatter due to brittleness at a later date. Replace at least the valves in this hole.
BT
BT
Roby
