502 Question >
502 Question
502 Question
Old 07-29-2004 | 03:46 AM
Default 502 Question
How Many Hours Before You Rebuild??
Jason
32 thunder is offline
Old 07-29-2004 | 04:09 AM
Default Re: 502 Question
That depends on how you drive it and how you maintain it. Somewhere between 50 and 1000.
Griff is offline
Old 07-29-2004 | 04:15 AM
Looking At A Boat And It Has 680 Hrs All River,fresh Water Don't Know How It Was Driven. Any Tricks Or Hidden Stuff I Should Look For!! Will They Really Go 1000 Hours!!!
Old 07-29-2004 | 06:30 AM
GLH's Avatar
GLH
GLH is offline
Old 07-29-2004 | 07:38 AM
HiPerf2000's Avatar
Jason
That's a loaded question. I think Griff summed it up
Have a leak down test done one the motor. will tell you everything.
P.S. i know a guy in a 1988 40 Silverton that has 2000 hours on his original 502's.
HiPerf2000 is offline
Old 07-29-2004 | 07:46 AM
Get a leakdown and a Dyno run done on the engines. Still there are no for sures on used engines.But 600 hours is very high. Just price it out planning on freshening up the engines before they blow. This should run around $3,000 per engine vs. 10,000 each if you blow one and screw the blocks up.
HOTTZU98 is offline
Old 07-29-2004 | 08:12 AM
TAKE IT FROM SOMEONE WHO BUILDS AND WARRANTIES THESE ENGINES WHEN THESE ENGINES SHOW UP HERE WITH 600 TO 650 HRS THEY ARE READY FOR MAJOR REPAIR THE ENTIRE VALVE TRAIN NEEDS TO BE REPLACED PISTONS BRGS THE ENTIRE PACKAGE NEEDS TO BE GONE THROUGH I HAVE SEEN THEM GO 1000 HRS WITH JUST THE VALVE TRAIN REWORKED.HOPE THAT HELPS YOU OUT. LAZ MESA WWW.MESABALANCING.COM
PS THESE ENGINES MECHANICALLY ARE NOT SUPER EXPENSIVE TO REBUILD.
MESABALANCING is offline
Old 07-29-2004 | 05:48 PM
articfriends's Avatar
I agree w/mesa&hottzzu,if you buy this boat plan on rebuilding the motors,680 hrs is considered pretty high around here
articfriends is offline
RollWithIt
9
07-01-2008 07:51 PM
ThruHull
8
02-27-2007 06:04 AM
tanner
10-27-2006 06:27 PM
formula271
6
09-07-2005 11:00 AM
