Shot Gimbals >
Shot Gimbals
Shot Gimbals
Old 07-29-2004 | 05:04 AM
34scarab's Avatar
Default Shot Gimbals
Hey, I am looking for a little help/advice here.
My boat developed a vibration getting on plane.
Come to find out my gimbal rings are worn out.
These are 1988 vintage bravo-1's.
I am running the 525 SC's.
The shop highly recommends replacing with the HP gimbal rings.
It's a big job, but they can do it with out pulling the motors.
Do you think this is a good idea, expensive but... and how is the ring changed with the motors still installed?
Thanks.
34scarab is offline
Old 07-29-2004 | 06:54 AM
Default Re: Shot Gimbals
ok...the cut two holes in the transom ass. to access the nut(s).
do you have external steering?? you should!
audacity is offline
Old 07-29-2004 | 06:58 AM
34scarab's Avatar
Yes!
Full Latham hydraulic steering.
34scarab is offline
Old 07-29-2004 | 07:27 AM
i would pull the engines...you will find other stuff that could bite u later on as well....
audacity is offline
Old 07-29-2004 | 08:56 AM
blackhawk
I agree, pull the motors. I replaced mine 2 years ago and there was no way I was gonna drill two big holes in my gimbal assy. So, I decided to take on the big job of pulling my motor myself. Turns out, it's not a big job at all! I could not believe how easy it was to pull the motor. A 525SC may be a little more difficult but it can't be that much worse.
Audacity is right, you'll probably find something else wrong when the motors are out and be thankful you did. I found a couple of little things. I'm gonna pull the motor every 2 years just to check everything out from now on.
Old 07-29-2004 | 09:07 AM
Might thing about replacing the couplers while it is out...
BadDog is offline
Old 07-29-2004 | 11:51 AM
Mr Gadgets's Avatar
Charter Member #601
I would definitely upgrade to the HP gimbles. I broke a standard one, at 80mph and it is not good. Too long a story for here.
I have removed the transom assembly without fully pulling the motor, but it is a lot of work. I would pull the motors, and as everyone has said, you will find more. If they are 88 vintage, you might look at repacing the whole transom assembly. Sounds like a good project... if your up to it, instead of paying the shop..
good luck.. we have all (alot of us) been where you are now.
Mr Gadgets is offline
SLINGSHOT
04-06-2007 06:23 AM
Roger
02-05-2007 01:55 PM
articfriends
11
12-31-2006 02:28 PM
Quiet Storm
40
02-03-2005 05:21 PM
Jolley
05-14-2003 09:47 PM
