330 head size and piston >
Old 07-29-2004 | 10:15 AM
CAPTAINRON's Avatar
Default 330 head size and piston
Gentlemen, I need an education in stock 454 heads and compression ratios.
What does a standard 330 454 have in terms of c/r?(this is a 1982 model)
Also, what type of piston comes in this standard 330 domed, flat?
I am currently rebuilding a 330 454 and would like to have about 8.75 c/r.
I have the open chamber big oval port heads (I think 118 cc). should I go with a domed or flat piston?
Every thing I have read shows the 7.4 mpi (310 hp) to have 8.7 c/r or so but I dont know what type of pistons are used in this application. In addition the 454 mag is said to have only 8.6 c/r again with what piston?
I would appreciate any help.
CAPTAINRON is offline
Old 07-29-2004 | 10:21 AM
dyno's Avatar
Charter Member #655
Default Re: 330 head size and piston
Ron where are you? I have a set od 330 heads that are ready to run ....you can have them cheap!!!!
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
randy carlson
2
07-03-2008 08:59 AM
jonyb
Baja
2
12-09-2005 03:59 AM
MnHowardCat
12
11-06-2005 12:08 PM
Chris288
12-13-2003 04:37 PM
KAAMA
23
12-09-2002 05:11 PM
