What is this? >
What is this?
What is this?
Old 07-31-2004 | 12:54 PM
migara422's Avatar
Default What is this?
I just took my prop off my bravo 1 and i noticed that there were this chunks of rubbers inside the lower where the shaft is, i got some pliers and took the rubber out also i saw in there and took off a little metal plate that looks like the bottom of an iron, im really puzzled about this finding, any help would be appreciated.
Carlos
migara422 is offline
Old 07-31-2004 | 01:00 PM
mcollinstn's Avatar
Default Re: What is this?
description is vague.
pictures or details please.
mcollinstn is offline
Old 07-31-2004 | 01:31 PM
migara422's Avatar
Here is where i found the stuff
Old 07-31-2004 | 01:33 PM
migara422's Avatar
Here is what i pulled from inside there
Old 07-31-2004 | 02:56 PM
David's Avatar
Looks like part of an exhaust flapper
David is offline
Old 07-31-2004 | 07:52 PM
mcollinstn's Avatar
Definitely.
I was assuming you were NOT running exhaust thru the lower unit. Apparently you ARE running exhaust thru the lower unit and that is indeed an exhaust piece.
Old 07-31-2004 | 11:04 PM
migara422's Avatar
This is the back of my boat, exaust thru hull not exaust.
Old 08-01-2004 | 09:52 PM
Official OSO boat whore
That sure looks like a flapper disk. The port is oblong like that. If you never had through prop exhaust, maybe the drive was on a boat that did?
Cord is offline
Old 08-02-2004 | 12:48 PM
MnFastBoat's Avatar
Charter Member#157
just because you are running thu hull does not leave out that you may still be running thru prop also
do you have the Y-Pipe?
I currently run both the y-pipe and Thru hull
so its possible
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 08-02-2004 | 01:16 PM
HiPerf2000's Avatar
I just replaced that Y-pipe flapper yesterday. That's exactly what it is.
If you do have a Y-pipe, you will want to replace the flappers. There is one on each side where the Y-pipe hoses connect the thru-hull pipe together. My flapper broke and it ended up letting water come back up through it, and filled my cylinders with water hydrolocking the motor.
HiPerf2000 is offline
