Jessel rockers
Hello, I have the Jessel system on my drag race car which has a big solid roller cam and very stiff valve springs. My 2002 Nordic Heat is running a 598 with a pretty big solid roller and psi valve springs with a lot of seat pressure,and I run the T & D system on it, which is pretty much like the Jessel but a little less money. On these applications these types of rockers provide great durablity. I agree with everyone else, if you are running a smaller cam and not a lot of valve spring and I probably would not spend the extra money. At the end of last season most of the valve train on my Nordic was trashed, so that is why I swithed to the T & D rocker system and the PSI valve springs which are factory cryo'd and triple heat treated and then we coated them in house with our antifriction coating. I will let you know at the end of the season if it was worth it. Good Luck to you! Glen
Lmarth-- I am running a stock length BMax with 1.3 ratio and a stock 30 pitch Bravo, but I am looking into the new Hydromotive 5 blade, if you look under the Nordic forum you will find my discussion with Nordic Heat. We first put this engine in last year and broke the Bmax twice. I broke the vertical shaft the first time and the coupler the second time. Dean was very nice to me and did not charge me and sent up a fresh reconditoned drive. It has been fine ever since, I have about 26 hours on it with the big motor. I think some of the problem may have been that I am use to taking off in a 9 second drag car. Can't do that with the heavy Nordic. I have learned to be very gentle with the throttle until there is enough speed and I have it trimmed out, then I can lean on it. The downside of the Bmax is the power the bigger gears rob, but it is worth it to me to keep the drive together. I forgot to tell you the 598 is an EFI quadrotor motor and there is a lot of torque. Drives do not really like that a lot! Hope she contiunes to hold up. - Glen
Glen-- I need a minute for this all to sink in- A Nordic Heat with a solid lifter, EFI, Quadrotor 598 ??? I'll bet you surprised a few "hot boats" with that set-up! You're probably working on the marine equivalent of wheelie bars! High-tide- don't misunderstand my comment. I loved your post- short and to the point!--Lou
thanks for all the info...sounds like with my dinky little flat tappet hyd. cams I can stick with Cranes and keep my money for other stuff.....
If your boat has a sail do you ride a horse to the ramp?
Personally, I would not use Crane rockers. I prefer Comp Cams Stainless rockers, they have a much bigger bearing that would most likely be more durable. I am going with those for my 540 build-up.
I've used Cranes,Comps and Harland Sharps in the past with fair longevity with all of them....they seam to go about 300 hours and then show signs of wear.
