Jessel rockers >
Jessel rockers
Jessel rockers
Old 08-04-2004 | 08:28 AM
cryoracer
Default Re: Jessel rockers
Thanks Lmarth-- True we have surprised a few. We modified the hatch just a bit and it looks stock when you first see it. My Buddies all give me a hard time because a lot of the time we are just out crusing slow and we keep a lot of stuff up under the cuddy. It really is a family boat, we just put some umph behind it. Fun in the Sun!
Old 08-04-2004 | 10:18 AM
cstraub69@comcast
Your better off with an aluminum rocker. Yes they are not as rigid as a steel rocker but they absorb harmonics in the valvetrain. Steel rockers amplify harmonics that is why the Cup boys run aluminum.
Chris
Old 08-04-2004 | 11:06 AM
dyno's Avatar
Charter Member #655
Chris ....good info I never thought of that....
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 08-04-2004 | 01:01 PM
Chris--Excellent point!--Lou
Lmarth is offline
Old 08-04-2004 | 01:56 PM
cstraub69@comcast
Lou/Dyno,
Well it kinda helps when you use to work for a rocker mfg and have seen the R&D first hand.
Chris
Old 08-05-2004 | 06:34 AM
dyno's Avatar
Charter Member #655
Wesco wont let a motor go out of the shop with anything else.....
dyno is offline
Old 08-05-2004 | 09:12 AM
Mr Gadgets's Avatar
Charter Member #601
Cstraub69,
"Your better off with an aluminum rocker. Yes they are not as rigid as a steel rocker but they absorb harmonics in the valvetrain. Steel rockers amplify harmonics that is why the Cup boys run aluminum."
And what type of problems do you see with amplified harmonics, valve float at lower rpm? or damage??
I have been running Crower SS rockers for years and the only complaint I have is they dont properly line up with the valve stems in some cases. I have had to cut and weld push rod guide plates to compensate. Next time around it will be T&D or Jessel or a shaft type setup.. with more fingers and valves to mess with..
Dick
Mr Gadgets is offline
Old 08-05-2004 | 09:48 AM
cstraub69@comcast
Dick,
The most detrimental was spring harmonics and premature failure of the valve spring. In testing of components by the boys in NC, valve springs would last longer with aluminum rockers.
I would also recommend on any boat engine with 600HP or more to run a single or dual tapered pushrod to prevent deflection. Deflected pushrods rebound after max lift and can cause lifter damage after a period of time. The large 7/16" tapered stuff prevents this and in most cases is worth some extra hp. I had this happen to Jasper engines 2 years ago in a 417 CID SBC dirt engine. You could tell the deflection was happening by the SCFM fluctuation on the dyno sheet. I told them to change the pushrods, quite long, 9.500". Well they decided the next morning to pull her one more time and she spit 2 pushrods out. I had some 7/16" to 5/16" single tapers made for them and the engine picked up 40HP, which for any engine is a sizeable gain.
Chris
bsirk
7
06-04-2008 10:13 AM
HARRISONMIRAGE
10
01-25-2004 07:53 AM
DaBeezer
02-04-2003 04:46 PM
