1998-2000 33 Outlaw    How fast?? >
Old 08-03-2004 | 06:03 PM
Smitty's Avatar
Default 1998-2000 33 Outlaw How fast??
I am considering a 1999 33 Outlaw with 502 EFI motors and I was looking for some idea of what kind of speeds people are seeing with this setup. I need a baseline number for my calculations. I do know it has Mirage 3 blade props on it now, but I don't know the pitch. I would guess probably 25"
Smitty is offline
Old 08-03-2004 | 07:01 PM
Default Re: 1998-2000 33 Outlaw How fast??
My guess would be around 70?
mike0311 is offline
Old 08-04-2004 | 05:13 AM
BURNSMAZZ's Avatar
I've got a 98 33' Outlaw 454 mags 24" turbo vector 3 blades and I run consistently 68-70mph on gps depending on water, load etc...
BURNSMAZZ is offline
Old 08-04-2004 | 09:29 AM
bajadude's Avatar
'99 33 with HP500s, labbed 26p B1s 74 - 75
bajadude is offline
Old 08-04-2004 | 10:59 AM
Steel Outlawed's Avatar
I would say 70 on gps.
Steel Outlawed is offline
Old 08-04-2004 | 11:23 AM
outlawinil's Avatar
If the speedometer works probably will show 74 but if you use GPS I'd put my money on 68-70. I have a 2000 model that started out with 7.4L MPI 310hp motors. 60 mph on a good day with 23 mirage plus. Now 500hp's and labbed 27's around 77. All GPS numbers.
You can do the math on 454 mags and 502 mags and get a good idea. I'd say the 25's are where you want to be propwise.
outlawinil is offline
Old 08-04-2004 | 01:52 PM
outlawinil's Avatar
Hey it's a boring day here so I did some math. From my experience 310's will get you 60 mph and 500hp's at 470hp will get you 76. So:
310x2=620
385x2=770
415x2=830
470x2=940
Speed difference of 16 mph and total hp difference of 320. That means it takes 20 hp to go 1 mph faster.
My guess(uneducated too):
454 = 60 mph
454 mag = 67.5mph
502 mag = 70.5mph
500hp = 76 mph
Old 08-04-2004 | 04:39 PM
A friend of mine's 99' with 502's
turning 25p mirages +'s runs 68-70.
jt
JaayTeee is offline
Old 08-04-2004 | 08:35 PM
liquid asset's Avatar
2001 33 502's 23" mirage plus 68.5 gps at 5,000 at 400' ele. in TX at 95 degrees
liquid asset is offline
Old 08-09-2004 | 08:14 AM
Smitty's Avatar
Outlawinil--
Thanks for taking the time to run the numbers. Thanks to everyone else who posted up their info. I am all over the board on my search for a new ride. I found a 33 with HP500's that might work. I don't think the 502's are enough. I also found a 36 with Whipplecharged 502's that the guy says runs mid 80's. I find that hard to believe. I will see that boat in about two weeks. We'll see what my handheld gps says !!!
Dave
Smitty is offline
