Bravo 1 wont go up while going high speed >
Old 08-09-2004 | 07:11 PM
migara422's Avatar
Angry Bravo 1 wont go up while going high speed
Hi guys, i dont know what is the matter with the drive if im going over 60 it doesnt want to go up, if i slow down to like 30 or stopped then it will go up, any ideas?
migara422 is offline
Old 08-09-2004 | 07:21 PM
MACDAD260's Avatar
Charter Member #818
Default Re: Bravo 1 wont go up while going high speed
Your trim pump may be getting weak and does not have the pressure to overcome the force of the prop pushing the drive down or forward at high speed. At lower speeds there is not as much forward force being exerted.
MACDAD260 is offline
Old 08-09-2004 | 08:11 PM
battery
I ran into this problem a few years back also. Check to make sure the hydraulic lines to the drive are not swapped. The trim pump only puts out 400 psi on the trim down circuit but puts out 2400 psi on the trim up circuit. The trim pump line connections are marked on the pump casing at the connection boss.
Old 08-09-2004 | 08:14 PM
Downtown42's Avatar
http://www.mercruiserparts.com/Show_...HYDRAULIC+PUMP
BAM parts- trim pump above link.
I kind of got the same except mine will droop slowly down while running or sitting on my trailer.
Downtown42 is offline
Old 08-09-2004 | 09:06 PM
migara422's Avatar
Thanks for the advice, i had a problem with the drive since i bought the boat, when you hit the switch it would wait couple seconds before going up or down, maybe gettting worse.
Old 08-10-2004 | 06:27 AM
Mbam's Avatar
Offshoreonly Advertiser
Sounds like a cylinder with an internal leak
Mbam is offline
Old 08-10-2004 | 12:58 PM
StrikinLightnin's Avatar
Too Old has new pumps at a great price!
I ordered two of them from him today.
StrikinLightnin is offline
Old 08-10-2004 | 01:25 PM
migara422's Avatar
thanks for the info, but i would hate to buy a pump if in case its the cilinder like bam is saying, how could you check if that is really the case?
Old 08-10-2004 | 01:52 PM
Trim drive down and remove one cylinder. Attempt to trim drive up against a force. Repeat process and compare results.
Trim drive up and remove one cylinder, see if it bleeds down on it own. Repeat process.
Look in the Merc manual and see if there is a pressure test. The first two is what I would do just for the heck of it while emptying a cooler. If they don't provide anything
BadDog is offline
Old 08-10-2004 | 01:54 PM
I would also check the relays mounted near the trim pump, one could be weak and not allowing the full current to reach the trim pump. You might try swapping them with each other. How does the pump fluid look?
BadDog is offline
