What are concerns over low vacuum pressure? >
Old 08-09-2004 | 11:14 PM
minslee2
Default What are concerns over low vacuum pressure?
I am no expert here... anybody know where vacuum pressure should be on a 454?
Got a friend with a custom 28' cruiser with a 330 h.p. Mercruiser 454, and a TS outdrive that throws a large prop. He doesn't want to take the engine over 2600 r.p.m. and is super cautious about vacuum pressure being low. Long ago the boat was known to do 4000 - 4400 r.p.m. at about 40 m.ph., but someone said low vacuum pressure was a bad sign, and when he revs, the vacuum pressure falls, so he won't push the r's. So the low rpm and big prop lugs the engine and outdrive, I think to the detriment of the outdrive. The boats gone through prop hubs pre-maturely, and it may be too much lug on the prop/drive.
Old 08-09-2004 | 11:20 PM
minslee2
Default Re: What are concerns over low vacuum pressure?
Sorry, I meant a 454 with a TR outdrive (not a TRS).
Any help much appreciated!
minslee2
Old 08-10-2004 | 08:24 AM
I think your friend is confused. Low vacuum AT IDLE could indicate a problem. It is supposed to drop as you throttle up the engine. Too big a prop, resulting in only 2600 rpm max, will prematurely destroy the engine.
See attached:
http://www.marinemechanic.com/site/page55.html
Gary Anderson is offline
Old 08-10-2004 | 09:03 AM
Airpacker's Avatar
Vacum at idle should be somewhere between 17 and 21 inches of mercury. Vacum on a loaded engine at WOT should be approximately 0 (zero) as the pressure under the carburetor throttle plates nears atmospheric pressure. Low vacum at idle can indicate a worn camshaft, worn(stretched) timing chain,
bad valve sealing,worn rings or just mal adjusted ignition timing. A rapidly fluctuating reading can indicate a burnt valve or broken valve spring. Check it at idle and if it ok, tell him to forget about it. Reading 0 under throttle is ok.
Airpacker is offline
Old 08-10-2004 | 10:00 AM
PatriYacht's Avatar
Vacuum drops as you open the carb butterflies and allow atmospheric pressure to equalize. Completely normal. Fuel consumption tends to go up as manifold vacuum goes down.
PatriYacht is offline
MnFastBoat
12
06-23-2008 07:07 AM
minslee2
08-10-2004 09:09 AM
riverboater
2
08-05-2004 08:13 PM
jimjomack
6
09-08-2003 02:31 PM
Ric232
7
03-24-2003 10:49 AM
