Anti-siphon Valve, Where Is It? >
Old 08-11-2004 | 03:28 PM
f252tbird
Default Anti-siphon Valve, Where Is It?
Iv'e Been Told The Anti Siphon Valve In My Fuel Tank Is Clogged And Needs To Be Replaced. Don't Know Where It Is Or How To Do It. Help Please.
Old 08-11-2004 | 03:40 PM
Turbojack's Avatar
Default Re: Anti-siphon Valve, Where Is It?
Most time I have seen them is right on the tank with the fuel line attached to it.
Turbojack is offline
Old 08-11-2004 | 03:58 PM
f252tbird
My Fuel Line Attaches To A 90 Degree Fitting On The Tank Is This It?
Old 08-11-2004 | 05:08 PM
yes, that is it!
Formula29 is offline
Old 08-11-2004 | 05:31 PM
Turbojack's Avatar
The last one I saw was anti-siphon/hose bib all in one. When taken out there will be a ball in the middle of it.
Old 08-11-2004 | 05:41 PM
jhnrckr
Mine was on the top of my tank, right next to my fuel level float underneith an access panel in my floor. I doubt it is clogged but it is restrictive and your motor will start much easier without it.
Old 08-11-2004 | 06:28 PM
f252tbird
Ok, Next Question. Is This Separate From The Pick Up Line Or Will I Need To Replace The Entire Piece?
Old 08-11-2004 | 06:53 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Should just be a screw-on fitting
US1 Fountain is offline
Ginger or Mary Ann?
How do you know it is clogged?
Old 08-11-2004 | 08:39 PM
I just had this same issue a couple of weeks ago. Mine was a combination anti-siphon/ hose bib screwed into the 90 degree fitting on the tank. It looked fine when I took it out, but I replaced it with an Evinrude/ Johnson factory replacement part. It's a quality brass unit, and the opening in the hose bib was a bit larger than the old aluminum one that was on my tank. Needless to say my stalling problem went away.
Liberator21 is offline
