Oil Temps / Pan or Cooler? >
Old 08-28-2004 | 11:09 PM
Default Oil Temps / Pan or Cooler?
Ok, I'm running a HP500. I have two oil temp gages in my boat. The sending unit for one of the gages is in the center of the lower oil filter base at the back lower part of the engine. The other sending unit is in the block on the same lip that the oil pan bolts to.
The gage which has the sending unit in the block where the oil pan bolts to shows 260 degrees when I'm running it hard. The other gage which is reading from the center of the lower oil filter base is reading 225 degrees.
Where should I be reading the oil temp and should the pan oil get that hot???
Thanks in advance,
Mike
Active Mike is offline
Old 08-29-2004 | 07:33 AM
Default Re: Oil Temps / Pan or Cooler?
the sending unitin the filter housing is reading the oil temp prior to the oil cooler.the other sending unit is reading it after the cooler. oil temps a lillte warn. are you running the filter housing with the oil thermstat if so by pass it. and check your temps agian
CMS Racing is offline
Old 08-29-2004 | 10:53 PM
CMS,
Your saying that the sending unit in the center of the filter unit is reading the oil before the cooler and the one on the oil pan rail is reading after the cooler?
That doesn't support what I'm seeing on my temps.
Yes I'm running a T - stat unit on my boat and I have replaced the stat unit in it to make sure that that wasn't the problem and I seen no change.
Thanks for the help.
J. Hordubay
13
10-02-2008 01:55 PM
31scarab31
2
02-29-2008 04:14 PM
slik22
Wanted
6
01-08-2008 04:13 PM
Mr Gadgets
58
12-21-2007 11:54 AM
patrick22309
5
06-20-2003 05:53 PM
