What props work best on TRS's? >
Old 09-01-2004 | 08:36 AM
Default What props work best on TRS's?
Working to learn as much as I can about my old 28SS with TRS's. It's got Bravo1 props now and I'm wondering if I should be looking for another, perhaps older (?) design that may work better with those old drives?
Specifically, 22p Bravo1's turning 4400rpm and 56mph on the GPS.
What have you guys experienced?
JohnJan is offline
Old 09-01-2004 | 08:39 AM
Perfectmix's Avatar
Default Re: What props work best on TRS's?
johnjan
What power are you running? I assume the props you have now are 3 blade.
Perfectmix is offline
Old 09-01-2004 | 10:04 AM
My suggestion would be more concern about how deep the drives are and the weight and design of the hull. Bravo 1 props don't always work the best when drives are deep. Sometimes they are too much blade. If your drives are pretty deep in the water you might even look at some used Mach Sterndrivers. They will never replace Bravo 1's generally but in some cases they can work well. Especially with modest power.
deboatmon is offline
Old 09-01-2004 | 10:12 AM
My 28 Pantera Had Mirages 25p With Trs Drives And Hydromotive Nose Cones.spinning In Instead Of Out.went 80 All Day With 450 Hp Each.at 5000 Rpm.
z.zuperboat is offline
Old 09-01-2004 | 10:33 AM
Pat McPherson's Avatar
I had a 28ss with 280small blocks and TRS drives.
She came with 21p 3 blade cleavers and would run 63 at 5200rpm, but was a dog out of the hole.
We tried ø14-5/8 x 21p Mirages and ø14-1/2 x 21p Turbo Vectors.
About 60mph @5000 with either and much better out of the hole.
I think you will be better off with smaller diameter 3 blade props.
Never tried Zuperboats suggestion, that may lift that heavy stern and gain so speed too.
Patrick
Pat McPherson is offline
Old 09-01-2004 | 10:39 AM
Mine Also Came With 25p Cleavers Went 65mph Traded Up To Mirages And Went 75 Then Labbed And Spinning In Went 80.spinning In Lifted The Bow With Less Trim. Heyy Patt Watzzz Zup.
Old 09-01-2004 | 11:31 AM
Great info guys! The Bravo1's are 4 blade. It never snapped to me about the deep X. I've got some 23p Mirages that came with the boat. Didn't immmediately toss them on because I'm only turning 4400 with the tired 383's in the boat now. Less blade may allow them to loosen up a bit and at least reach that rpm.
JohnJan is offline
Old 09-07-2004 | 10:23 AM
Tried the 23 inch Mirage's this weekend and with an additional 100gals of fuel from last time out the boat still picked up 4 MPH at the same WOT RPM. WOW!
JohnJan is offline
Old 09-07-2004 | 10:29 AM
just think minus 600lbs for 100 gal. you should get 2-3 more
Old 09-07-2004 | 10:36 AM
Wally's Avatar
Were doomed!
My buddy's 28ss has Mirage 23's and run's 400hp smallblocks........spins at 5100rpm and runs 65mph all day
-Wally
Wally is offline
