Solution for Head Gasket troubles- Blown or N/A >
Old 09-07-2004 | 11:13 PM
blown formula's Avatar
The final solution to leaky head gaskets in High Compression or Blown engines is here!! The new NASCAR Stainless Multi-layer (3) head gaskets by Federal Mogul.
Go to :http://www.federal-mogul.com/cda/cha...2_7106,00.html
Available thru Fel-Pro dealers.
The only problem is cost- about $180-200.00 a pair!! even so, it's cheap by comparison changing gaskets & pulling engines.
blown formula is offline
Old 09-08-2004 | 04:47 PM
Infomaniac's Avatar
Default Re: Solution for Head Gasket troubles- Blown or N/A
Very nice. Looks just like these Cometic gaskets. Cometic has a standard coated outer layer and the center "shim" layer makes the total thickness.
Infomaniac is offline
Old 09-09-2004 | 08:34 AM
Strip Poker 388's Avatar
Rob
First I have seen of these. I wonder if there better than the lock wire gaskets they have ??This would be a lot easyer
Strip Poker 388 is offline
Old 09-09-2004 | 11:03 AM
hotlavey's Avatar
Wonder what is does to the compression ratio? Also on their application chart it does not show GM V/8's.
hotlavey is offline
Old 09-09-2004 | 12:33 PM
Smitty's Avatar
A big help is to also use ARP head bolts or if you have the room,ARP studs.
Studs have the best clamping force.
Smitty is offline
ur2slo
08-17-2006 10:01 PM
jboater
6
05-08-2005 11:51 AM
jboater
0
05-07-2005 06:38 PM
28Eliminator
24
08-29-2003 07:59 PM
