Air Pump For 1991 Corsa Mufflers??? >
Old 09-09-2004 | 09:56 PM
Ed
Question Air Pump For 1991 Corsa Mufflers???
Circa 1991 Cigarette 31' Bullet with Corsa internal switchable mufflers. The air pump is no longer available from Corsa, they say. The system is simply, soft clear plastic push-on tubing(like aquarium tubing), with push-on barb fittings on the old air pump. Standard looking air cylinders...BUT...I need a new replacement pump. Don't have the old one. Anyone have a clue about a source for this??? Thanks, Ed
Ed is offline
Old 09-10-2004 | 03:55 AM
cig1988's Avatar
Default Re: Air Pump For 1991 Corsa Mufflers???
Would merc pn 01534152 work? Just changed it on the '89 Bullet.
cig1988 is offline
Old 09-10-2004 | 09:21 PM
Ed
Cig...Do you have Mercruiser Silent Choice diverters or Corsa like mine? Ed
Ed is offline
Old 09-11-2004 | 06:19 AM
cig1988's Avatar
It's the stock mercruiser silent choice. If it's operation is the same I could'nt see why it would'nt work. Check out mercruiserparts.com (BAM) and plug in the part#. Marc @ Bam would be able to tell you if it will work for sure.
cig1988 is offline
Dave98
Powerquest
10
04-19-2008 10:21 AM
wolfdog
04-24-2007 09:38 PM
C_Spray
04-20-2005 11:38 AM
Lickitysplit
6
06-24-2002 09:54 PM
Magicfloat
0
04-02-2002 06:07 PM
