OMC 460 Cobra exhaust risers >
Old 09-11-2004 | 03:39 PM
Default OMC 460 Cobra exhaust risers
Any suggestions on where to find stock risers? It seems nobody makes replacements (aftermarket) and there is a "national" backorder until Dec. from Bombardier. These are for a Donzi 33.
stevehaolecrab is offline
Old 09-11-2004 | 04:14 PM
mopower's Avatar
Toxic FORMULA
Default Re: OMC 460 Cobra exhaust risers
Depends on how desperate you are , but I had a 460 KC and used Imco Powerflows for a BBC with adapter plates that were also made by Imco.
If you compare a BBF and BBC exhaust gaskets you'll find the centerline on the ports are almost identical. The adapter reshapes the ports and relocates the bolt holes. It's even tapered at the top to cause the riser to tilt inward to it's original location
mopower is offline
stlliberator
36
09-04-2007 01:19 AM
BAJA WILL
07-19-2007 02:49 PM
MidnightRider
04-11-2007 02:56 PM
24Baja
0
09-20-2004 02:13 PM
thedonz
04-08-2003 09:23 PM
