trim cylinder hyd line leaking
trim cylinder line going through the transom cutout for the outdrive is leaking. the line operates the trim cylinder on the outdrive. the boat is a 1988 cigarette bullet with bravo one drives. do i have to pull the drive to repair the line.
If you buy one of those little brass flare connectors, connect the new one to the old one, and you can feed the new line in while pulling (carefully) the old one out.
