420 Belts, Pulleys, and Idler >
Old 09-14-2004 | 04:51 PM
Default 420 Belts, Pulleys, and Idler
I am looking for a drive Assembly for the 420 Mega blower!
If you have some laying around Please let me know the size of the pulleys! style of Pulley, Gilmer or rib belt!
Bryan
bpine is offline
Old 09-15-2004 | 06:38 AM
Mbam's Avatar
Offshoreonly Advertiser
Default Re: 420 Belts, Pulleys, and Idler
I have a bunch of stuff for both 8MM and 16 groove rib. You need to have an idea of the ratio you want and the center to center on the crank and blower snout.
Mbam is offline
Old 04-01-2021 | 12:15 PM
We have a pair of 454's with 420 mega blowers. would like to make around 8lbs of boost. I have a 16 rib set up and my upper pulleys are only 4 7/8' my lower pulley is 4 1/2'. To much I would assume. what would you suggest?
offshoreratboy is offline
Old 04-01-2021 | 12:25 PM
B38
Top and bottom pulley same bolt pattern. Swap when in need HP.
try your current setup, just stop when it reaches 5lbs of boost your safe.
Stand on it, goes to 7 lbs then go 1/2" up on top pulley
B38 is offline
Old 04-02-2021 | 06:56 PM
B38
I believe I have an idler bracket for 16 rib like photo. 420 Merc blower. 5 lbs boost
B38 is offline
Old 04-05-2021 | 08:42 AM
18 5/8" center to center. I would like to go to 8MM so I would need upper lower and Idlers. But if to expensive Ill stick with 16 rib. and only need uppers.
they are 454's with 420s and I would like to make six lbs or so.
You can reach me @ 440-585-2002 Joe
fastlane40
Swap Shop
0
09-16-2008 03:56 AM
txriverrat2001
0
03-17-2008 09:00 AM
ghittner
3
09-27-2007 10:24 AM
delsol
5
07-11-2007 12:04 AM
ghittner
2
08-15-2006 12:18 PM
