TRS Gear Housing >
TRS Gear Housing
TRS Gear Housing
Old 09-15-2004 | 01:55 PM
38KV's Avatar
Default TRS Gear Housing
Broke a skeg last weekend. Broke it so bad I can't weld it.
Looking for a used empty TRS gear housing in good shape.
Does anyone know if the RH and LH rotation
TRS use the same lower gear housing or not?
38KV is offline
Old 09-15-2004 | 01:57 PM
Biggus's Avatar
Default Re: TRS Gear Housing
Yes, the left and right share the same housing.
Give Mark at BAM a call. He will have a new one.
Kurt
Biggus is offline
Old 09-15-2004 | 02:02 PM
tomtbone1993's Avatar
Dave ATB engine has used ones 936-344-7200
tomtbone1993 is offline
Old 09-15-2004 | 02:07 PM
38KV's Avatar
Thanks!
38KV is offline
Old 09-15-2004 | 02:23 PM
Biggus's Avatar
If you find a used one make sure it has never been repaired from a blown gear. They tend to "stretch" and you will never get a correct gear pattern.
Biggus is offline
Old 09-15-2004 | 03:21 PM
38KV's Avatar
Thanks for the info Biggus. I want to find a used one because I'm considering
Konrads in a near future and don't want to spend that much $$$ on the TRS drives.
38KV is offline
Old 09-15-2004 | 03:28 PM
Biggus's Avatar
Good move.
I've logged just over 100 trouble free hours on my Konrads. They are rugged as hell. I can't break 'em.
Kurt.
Biggus is offline
Old 09-15-2004 | 03:54 PM
38KV's Avatar
Kurt, do you mind if I pm you if I have some questions
regarding the Konrads later on?
Jonas
38KV is offline
Old 09-15-2004 | 03:59 PM
Biggus's Avatar
No problem.
Biggus is offline
Old 09-16-2004 | 07:22 PM
Lofty's Avatar
Jonas,
I've got a couple of lower cases you can have if you're interested. PM me with you shipping info.
Fionn
Lofty is offline
