Supercharged Engines...Life expectancy >
Old 09-26-2004 | 07:42 AM
Comanche3Six's Avatar
Default Supercharged Engines...Life expectancy
I just completed 8 seasons with the same engine. No smoke, knocks, rattles, oil leaks or usage or connecting rods exiting through the oil pan. How about them apples?
Comanche3Six is offline
Old 09-26-2004 | 07:56 AM
GLH's Avatar
GLH
Default Re: Supercharged Engines...Life expectancy
Your suppose to crank it and make it run however...
GLH is offline
Old 09-26-2004 | 08:40 AM
I knew I forgot something.
Old 09-26-2004 | 08:50 AM
Originally Posted by sutphen30
what motors are they and how many hours total on them of run time.
522ci BBC.....300 plus total hours
Old 09-26-2004 | 09:11 AM
how much boost, hp? How hard do you run them etc?
TxHawk is offline
Old 09-26-2004 | 10:03 AM
4-6 lbs boost...some idling, some full throttle, mostly high speed cruising. A lot of oil and filter changes. No Airplane imitations. Never had a valve cover off.
Old 09-26-2004 | 02:26 PM
now that's what I want to hear......now, my two little friends, are you listening?....I am going to feed you a lot of clean oil and oil filters.......stay healthy will ya......
thedonz is offline
Old 09-26-2004 | 02:31 PM
VelocityMark's Avatar
How much HP. What kind of blowers? And did you build them or did you buy them?
VelocityMark is offline
Old 09-26-2004 | 05:16 PM
This engine was never qualified for horsepower on a dyno. Heres the parts list.
Modified 1150 Dominator.
B&M 250 supercharger
MSD ignition
AFR prepared Merlin Heads
Gil Offshore exhaust
Crane Hydraulic roller cam
pete jackson gear drive
Merlin block
JE pistons
Oliver Billet rods
Moroso Offshore pan
Weston Machine shop handled the machine work.
I assembled and installed. It still idles smoothly at 900rpm and rips up to 5000rpm without a single hiccup.
Old 09-26-2004 | 06:35 PM
Biggus's Avatar
Parts list sounds great except for the gear drive.
I've never heard of a gear driven timing set-up lasting very long in a marine application.
Harmonics/same rpm @ long duration = short life
Biggus is offline
