TRS/Speedmaster 2, trim cylinder >
Old 09-27-2004 | 08:56 PM
bryanspeedracer's Avatar
Default TRS/Speedmaster 2, trim cylinder
I was testing my hydraulics and I noticed fluid leaking from the fitting closest to the piston. Tried to tighten it, but would not. Took it apart and the treads in the cylinder are stripped. Not REAL bad but enough that a fix is in order. It stripped from being cross treaded.
How do I fix this? Can I drill and tap it larger? Spoke to a hydraulic shop. They quoted $125 to fix it. Should I replace it (any used cylinders around)?
Help!
Thanks,
Bryan
bryanspeedracer is offline
Old 09-28-2004 | 08:14 AM
Default Re: TRS/Speedmaster 2, trim cylinder
Those are inverted flair compression fittings. If you drill + tap you'll have to get a new hose made with inverted flair on one end to npt on the other. If you check automotive, brake, and hydraulic shops, you may be able to find an npt to inverted flair fitting that would allow tapping the cylinder, using the npt to flair fitting as an adapter, and still use the existing line. Take the cylinder + line with you and see if they have that fitting.
Gary
Gary Anderson is offline
Old 09-28-2004 | 09:04 AM
Thanks Gary.
Old 09-28-2004 | 09:55 AM
Mbam's Avatar
Offshoreonly Advertiser
Drill and tap for 1/8 pipe and use an inverted flare adapter, 1/8 NPT to 3/16 inverted flare, same as a brake line. you can find it at an auto parts store. Don't even take it apart, use a vacuum cleaner to clean the chips.
Mbam is offline
Old 09-28-2004 | 07:09 PM
Marc,
Thanks a ton! Hey now that I got you here, what tranny fluid do I put in my velvet drive trannies?
Old 09-28-2004 | 08:02 PM
Mbam's Avatar
Glad to help. Use type F or FA (Ford spec), non synthetic.
Mbam is offline
Old 09-28-2004 | 08:12 PM
Marc,
Thanks a ton!
Old 10-06-2004 | 12:55 PM
Marc,
I fixed the cylinder tyhe way you described and it works like a charm.
I owe you a beer.
Thanks again,
Bryan
Old 10-06-2004 | 01:02 PM
Mbam's Avatar
Glad to hear it!!
Mbam is offline
Old 10-06-2004 | 03:44 PM
Hey, dont I even get an honorable mention on this one
SHAWNA
Wanted
2
09-02-2008 06:39 PM
jaxx 30
Scarab
13
07-25-2008 12:53 PM
stinger390
9
12-18-2006 03:39 PM
vtec
0
06-30-2005 12:20 PM
Poorsche
0
05-21-2005 04:54 PM
