carb jetting >
carb jetting
carb jetting
Old 09-29-2004 | 10:56 AM
Default carb jetting
Can any body give me a starting place to jet a 850 vac sec carb?I have a 30 foot wellcraft prima with a 502 that was bored .o60.The boat weighs 10000 pounds.The motor was a 502 zz but the compression was lowered to 8.75-1 and the cam was changed to a comp cam,.547 lift exhaust and intake
duration 230 intake and 236 exhaust.It has a bravo 2 drive 1.36 &18x19 prop.THANK YOU for your input.Lorne
lorne is offline
Old 09-29-2004 | 01:52 PM
Default Re: carb jetting
77 pri-86 sec ,.I read you other posts,I think you should do a full check of your fuel system.Rebuild & "adjust" carb,fuel pump check and or replace .
Dixie Doug is offline
rslick
0
07-06-2007 03:04 PM
trimman
8
07-01-2006 04:01 AM
AIR TIME
7
06-28-2005 02:19 PM
johnnyboatman
12
03-31-2004 09:28 PM
1Boatnut
5
07-28-2002 10:41 AM
