towing with a 2004 silverado SS >
Old 09-30-2004 | 09:08 AM
berns29scarab's Avatar
Default towing with a 2004 silverado SS
i have a 98 29 scarab with twin small blocks. in the midst of purchasing the above mentioned truck. towing capacity is rated 7500lbs...boat weighs 6300 and its on a triple axel steel float on trailer i believe trailer weight is like 2-2300 lbs but unsure. am i pressing my luck ? wont be used for long hauls..its 4 miles round trip to the ramp and maybe once in a while a longer trip...Jersey to NY something like that.
berns29scarab is offline
Old 09-30-2004 | 10:27 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Re: towing with a 2004 silverado SS
I think you will probably be OK. Just remember there is no such thing as too much truck. Get airbags on the truck. They have no payload capacity in the back, and it will sag when you stick the trailer on it.
Sydwayz is offline
Old 09-30-2004 | 10:31 AM
thought about that also...i'd like a 3/4 ton diesel but alot of $$$$$
Old 09-30-2004 | 10:39 AM
Tim G.'s Avatar
Performance Boat Center
Bern,
You have a nice truck..
I don't think you'll have any trouble unless you push your luck on the highway.... Just assume that you're a little overloaded, and drive it carefully...
I have pulled more with less...
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim G. is offline
Old 09-30-2004 | 11:16 AM
BajaRunner's Avatar
i had one with the 4l60e. get the 4l80e. i towed 6,000 pounds and tore it out 3 times. it was under the tow rating, but the constant shifting burned up the bands.
BajaRunner is offline
Old 09-30-2004 | 12:14 PM
hey tim i wanted to buy your pantera and spoke with Jo about it but was a little outta my range so i bought the Scarab instead...
Old 09-30-2004 | 12:15 PM
Tim did you ever sell it ? If not whats the BOTTOM BOTTOM LINE ! I love the looks of that boat. GORGEOUS
SDFever
16
03-10-2008 09:56 PM
Boomer35
10
11-25-2007 07:30 PM
rdp145
2
03-13-2006 06:51 PM
JBmarine
9
12-22-2005 07:22 AM
Magicfloat
16
03-20-2005 06:50 PM
