Need Help 500efi >
Need Help 500efi
Need Help 500efi
Old 10-03-2004 | 05:34 PM
scottsumrall's Avatar
Default Need Help 500efi
Ok, Heres The Deal, My Port Motor Tach Whats To Jump 300-500rpms While The Motor Is At 4k Rpms. We Have Ruled Out The Tach Due To Changing The Sender Wire, Which The Jump Moved To The Other Tach. Also We Had The Scan Tool Hook Up Which Show The Rpms To Hold At 4k On The Scan Tool. So This Would Rule Out The Motor. Please Help. The Motor Has Only 10hours 02 500efis. Thanks Scott
scottsumrall is offline
Old 10-03-2004 | 10:54 PM
Steamin Rice's Avatar
Default Re: Need Help 500efi
The tach is jumping 300-500 RPM, not the motor, right? If this is the case, I would troubleshoot the various portions of the link between the two motors. It sounds like you have already ruled out the gauge itself, correct? Is there a sender that you can check?
Steamin Rice is offline
Old 10-04-2004 | 08:40 AM
yes, we had the scan tool hooked-up and it was showing to hold on the scan tool. i will say that the scan tool does move a little on the rpms, but i was told that the scan tool would not hold the rpms right on that it would move due to the sedative matter of the computer. so this would rule out the motor. any ideas. thanks scott
Old 10-04-2004 | 05:13 PM
Anybody?
Old 10-05-2004 | 06:38 AM
Canada Jeff's Avatar
Run a jumper wire from distributor and the block! I had the same problem, talked with Mike Lavorsi, and he explained its a comon problem with the hp500's due to the piant. I ran a wire and solved the problem!
Canada Jeff is offline
ar15meister
02-28-2008 06:56 PM
stsrick
Sunsation
11
07-07-2006 06:11 PM
stsrick
Prop Talk
4
06-19-2006 06:23 PM
CAP071
Sunsation
7
10-07-2003 08:13 PM
