Check out center cushion!!!! >
Old 10-03-2004 | 08:27 PM
I wanted to add a little sleeping room to the 32 active thunder cabin so I built a center cushion for it. What do you guys think!!!
Attached Thumbnails Check out center cushion!!!!-dsc02699.jpg   Check out center cushion!!!!-dsc02696.jpg   Check out center cushion!!!!-dsc02700.jpg
32 thunder is offline
Old 10-03-2004 | 08:30 PM
Default Re: Check out center cushion!!!!
Picture makes the cushion look out of shape but it's not or is it??
Old 10-03-2004 | 08:31 PM
HiPerf2000's Avatar
how is it supported??
HiPerf2000 is offline
Old 10-03-2004 | 08:35 PM
Talking Re: Check out center cushion!!!!
Two base plates on the bottom of cushion like this picture 3 inch pvc pipe connected to it and two base plates on the other end of the pvc for support on the floor!!
Old 10-03-2004 | 08:38 PM
R Addiction's Avatar
AT Cult Member #3
Looks Great!! I plan on doing the same thing to my 25 this winter.
And how is it supported?
R Addiction is offline
Old 10-03-2004 | 08:40 PM
AT Cult Member #3
I thought so....
Old 10-03-2004 | 08:41 PM
Total cost
1. Sheet of wood 16.00
2. Two yards of marine material 14.00
3. Bed foam 20.00
4. Pvc 10 foot section 7.00
5. Base plates 2.99X4
6. Nut & Bolts stainless
____________________________________
Total Under 75.00
Old 10-03-2004 | 08:43 PM
HiPerf2000's Avatar
how does the 3 inch pvc pipe stay on the cushion? does it use those slots and lock in, or is that raised OD on the base a 3" diameter??
Old 10-03-2004 | 08:48 PM
Reed Jensen's Avatar
Convert your day cruiser into a "stabin' cabin"... all for $75.00....operators standing by to take your order.... but wait... call in the next ten minutes and we'll double your order for free!..........
Reed Jensen is offline
Old 10-03-2004 | 08:49 PM
The pvc slides over it , so I can take it off easy for storage!!
