will running rich result in smoke
Are you using oil? an internal water leak will carry water out the breathers once the oil temp gets up to 212F. To check the rings, do a leak down test, any engine shop can do this. It will indicate condition of rings and valve seats. Running rich a lot causes excessive piston/ring wear.
Mark
Mark
