241 Liberator Help? >
241 Liberator Help?
241 Liberator Help?
Old 10-08-2004 | 05:05 PM
Default 241 Liberator Help?
I Just Bought A Very Nice 1989 241 Liberator My ? Is About Speed And Prop I Know This Is Not A Fast Boat But It Rides The Rough Water Very Nice I've Rode In 30 Footers That Don't Ride That Nice Anyhow Can Someone Tell Me What Prop Came Standard On This Boat With 454 Bravo 1 And What Speed It Should Run It Is A Heavy Boat Thanks
dodsonartic1 is offline
Old 10-08-2004 | 05:32 PM
birdog's Avatar
Default Re: 241 Liberator Help?
Sorry..cant help..But, I had an 86 Lib with twinn 350s...Yes they are VERY heavy!....Good luck !.......Do a search on Liberators....We had some threads way back..."MILORD"....."MISDEMENOR"...I think Have/had Libs
birdog is offline
Old 10-08-2004 | 06:11 PM
mopower's Avatar
Toxic FORMULA
More that likely a 21" Mirage. I had a 1988 21' with a 460 Ford and OMC King Cobra. That had a 21" BUT was a smaller boat BUT also had 1.43 gears not 1.5 like Bravos. It should work out about the same.
mopower is offline
Old 10-10-2004 | 06:57 AM
masi242's Avatar
I don`t know if this helps but I have a Formula 242 w/454 with a 1.5 gear ratio and I run a bravo 1 22 pitch labbed slightly and runs very nice. The boats I think are close in weight. Hope this helps.
masi242 is offline
Old 10-11-2004 | 07:57 AM
From: A tree somewhere in the woods in Clarcona Fl.
A friend of mine had one of the above mentioned boats,,,with a 21 mirage prop the boat woult run about 53 or so on a good day,,,,God what a tank though,,rode the same no matter what the water was like.
Slick02 is offline
Old 09-28-2005 | 04:22 AM
you can go on the fourwinns web site with a vin number and they can tell you what the boat came with.
hefty67 is offline
Old 09-28-2005 | 01:21 PM
Go to the Fourwinns website, and go to the archives. Select your year and model, and click on the "fast facts" (I think that's what it's called). There you will find engine sizes, drive ratios, max engine RPM,top speed etc.
Paul
Liberator21 is offline
Old 09-28-2005 | 01:58 PM
Carbon Footprint's Avatar
Dodson-
email me with your contact info, I'd like to talk to you about your boat.(I have an 89 241 with t/350's)
[email protected]
Carbon Footprint is offline
jmherbert
Prop Talk
16
06-12-2008 07:52 PM
rcarney
7
10-06-2006 07:04 AM
hefty67
7
10-05-2006 03:51 PM
Carbon Footprint
08-08-2005 07:52 PM
Carbon Footprint
07-22-2005 08:12 PM
