Transom Help
I have decided to replace the transom on my 1979 Formula 255 later this year and I am really considering going back in with dual power. Kaamaman has agreed to make a pattern of his transom but his drives are #1s and mine are TRS. Will the drive pattern be close enough to work, or will I be back to square one trying to figure out the x, y, and z placements?? Any comments or suggestions?
Steven
Steven
You will be back to square one. If you are doing big blocks the drive centers are 30" MINIMUM. I can give you height that my 302 is off the bottom but I would go higher then that if I was you.
Jon
Jon
Put your best foot forward!
Double R Performance
Nor-Tech
1
08-02-2006 11:34 AM
