Transom
Old 10-07-2007 | 02:04 PM
Default Transom
Anyone have an idea on how much it may cost to redo the transom for bravo's. I have kamma's on the boat and am considering switching to a bravo.
smoken02 is offline
Old 10-07-2007 | 10:12 PM
I would guess it to be around $2000-2500. They will probably redo the transom the same as if rebuilding a rotten transom and then have the tech you are using to install it cut out the hole for the transom assembly. It will depend on who you have do it and their hourly labor rate too so that can vary up or down.
Brandon is offline
Old 10-07-2007 | 10:56 PM
t500hps's Avatar
21 and 42 footers
I would assume the X dimension could be different requiring the motors to be raised/lowered to accomadate the bravo's....are you really sure you want to do this????
t500hps is offline
Old 10-07-2007 | 11:18 PM
Not sure, but I am worried about the availability of kaama parts and hp limit of the transmissions.
smoken02 is offline
Old 10-08-2007 | 07:37 AM
t500hps's Avatar
21 and 42 footers
I've never seen a Kaama so take this for what it's worth, there are a number of threads about Kaama's here and on other forums. Seems I've read the Kaama's are stronger than Bravo's (I think everything is!!) and the internal parts are primarily off the shelf items.
t500hps is offline
Old 10-08-2007 | 11:25 AM
Thanks, I will search the forum.
smoken02 is offline
Old 10-08-2007 | 11:49 AM
Audiofn's Avatar
Charter Member #232
Like T500 said the parts are available at most auto parts stores. There are a few guys that have manuals for them on the board that may be able to help ya out. The only bummer on those is the boot. If the boot goes or you hit something and crack the case then you are done. I would think that if you put on the Bravo's you will slow down a lot also.
Put your best foot forward!
Audiofn is offline
boatnt
Detailing, Painting, & Fiberglass
16
04-17-2008 07:02 AM
DORaymond
Cigarette
8
10-11-2006 04:04 AM
Hydrolift
5
09-13-2006 04:33 PM
Double R Performance
Nor-Tech
1
08-02-2006 11:34 AM
Prater
2
10-13-2004 11:05 AM
