Stroked 454 Or 502 ? >
Old 10-16-2004 | 10:07 PM
Default Stroked 454 Or 502 ?
What Would Be A Better Combo A .250 Stroked 454 =488 Or 502 In Heavy Boat
dodsonartic1 is offline
Old 10-16-2004 | 10:51 PM
KAAMA's Avatar
Default Re: Stroked 454 Or 502 ?
Actually, I believe adding a another .250" of stroke to a 454 would make it 482 cubes, +.030" bore would make it 489 cubes and +.060" bore would make it 496 cubes.
I kind of like the idea of the shorter stroke and larger bore size of the 502. It probably isn't going to make a whole lot of difference, but with the shorter stroke the rod angle makes things a little easier on cylinder, rings, and piston wear and less reciprocating weight being thrown around. If you were to take a the exact same components in a 496 vs 502 I am not exactly sure which engine would make more power. Perhaps the 496 would make more torque than the 502, but I am not exactly sure on that. Perhaps someone else can chime in here.
KAAMA is offline
Old 10-16-2004 | 11:10 PM
mcollinstn's Avatar
Bigger bore on the 502 does a far better job of unshrouding the valves. This results in better flow and better torque and power.
That's an easy decision.
mcollinstn is offline
Old 10-17-2004 | 09:42 AM
If indeed the boat is heavy I would most likely go with the stroker for better performance in the bottom speeds but the 502 is also a great engine . Good luck Laz Mesa
MESABALANCING is offline
Old 10-17-2004 | 10:15 AM
P Offshore's Avatar
Stroke the 502 from 4.00" to 4.25" and make it a 540.
I have a few if you need to purchase.
P Offshore is offline
DaleSC
06-10-2007 12:12 PM
k24u
6
11-27-2006 07:32 PM
Pat McPherson
17
11-01-2006 06:29 PM
Elite Marine
Pantera
10
03-11-2005 06:56 PM
checkmate981
9
05-17-2002 10:00 PM
