Identify This Carb??? >
Old 10-20-2004 | 05:42 PM
StrikinLightnin's Avatar
Question Identify This Carb???
This is a carb(s) that I inherited when I bought the boat.
I've been told that they are 750's that now flo out to 830's
The number 3913 and 6R3752B has been stamped on the body by the secondaries.
On the primary side is stamped P-46
On the secondary side R-24
I really would like to know what I have to work with.
Attached Thumbnails Identify This Carb???-img_0517.jpg   Identify This Carb???-img_0520.jpg   Identify This Carb???-img_0525.jpg
StrikinLightnin is offline
Old 10-20-2004 | 05:46 PM
Default Re: Identify This Carb???
Old 10-20-2004 | 06:25 PM
Reed Jensen's Avatar
It.... a..... looka like a Holley....
Reed Jensen is offline
Old 10-20-2004 | 06:31 PM
mopower's Avatar
Toxic FORMULA
With the choke horn machined off.
On my monitor it looks like it had some type of tag on the top of the bowls
mopower is offline
Old 10-20-2004 | 06:48 PM
The number you are looking for is/was on the choke horn... which appears to have been cut off... Without that... it just looks like a 4150 double pumper to me. Sorry.
Old 10-20-2004 | 06:49 PM
The tags were off when I got it.
The metering blocks have 11180 stamped on them.
The carbs were done by well known carb shop in Mississippi or Louisiana.
Maybe someone from that area could give me some insite.
Old 10-20-2004 | 06:53 PM
Maybe I should just trash the damn things and feed my engines
with an 850 Mighty Demon?
They're pretty funky looking old carbs
Old 10-20-2004 | 08:15 PM
robyw1's Avatar
Get a caliper and measure the ID of the body bore and the the throttle bore. I can get it pretty close for you then. The only reason they say it flows 830 CFM is because some idiot milled the choke shroud off instead of using a substack.
Roby
robyw1 is offline
Old 10-20-2004 | 09:01 PM
Roby
1.68" throttle bore
2.00" body bore
I took the body measurement of one bore from the outside machined edge to the center of the body?
Is this the correct way to measure?
Old 10-20-2004 | 09:22 PM
JCPERF's Avatar
looks like an 850.Turn it over and look at the flaps.180=850cfm.172=750cfm
JCPERF is offline
