Range of pitch for SSM props
When I was looking for props for my older SSM 3, I found pitches ranged from 26 to 30. Diameters ranged from 16 to 18. Found a set of 16s cut down to 15 1/2. Only found 3 blade props.
Also discovered that there is a hub insert (spacer) you can put on small shafts and use #6 props. Opens up a lot more possibilities.
Doug
Doug
Steamin Rice
2
09-28-2004 05:15 PM
