1988 350MAG Rebuild >
1988 350MAG Rebuild
1988 350MAG Rebuild
Old 10-28-2004 | 11:34 AM
BRIAN73's Avatar
Default 1988 350MAG Rebuild
Hello, Engine Guru's
A friend of mine is starting to rebuild his 1988 Merc 350Mag. New brgs,rings,gskts, ect......
Are the ring's and bearings standard?
He is going to mic everything to be sure, I just thought you guys might know of any roadblocks.
I basically need to know if a summit rebuild kit will do the trick or merc threw in some obstacles to prevent this.
Thank You
Brian
BRIAN73 is offline
Old 10-28-2004 | 02:10 PM
Iggy's Avatar
Default Re: 1988 350MAG Rebuild
First thing is for your friend to find a copy of Small-Block Chevy Marine Performance by Dennis Moore, HPBooks ISBN 1-5788-317-3.
In that book he will find a wealth of information.
A Merc 350 MAG is almost the same as a regular street 350. Some of the differences lie in the clearances for the main/rod bearings, piston to cylinder wall, and piston ring end gaps. The material that the intake and exhaust valves are made of is somewhat different too. Beyond that, it's all the same.
Iggy is offline
ECeptor
18
06-20-2008 12:56 PM
ontheh2o
24
12-03-2003 06:19 AM
patrick22309
1
08-25-2003 08:30 AM
wwwTOPDJcom
1
01-19-2003 02:25 PM
roadrat1
8
08-04-2002 03:06 PM
