496 engine rings
Hello all, I just bought a used 496 and noticed on a couple cylinders the rings where stuck also the rings where not staggered both in lined up is this normal to happen . The engine is a 2001 and had a bad valve I would like to change the cam ,but when you talk to different manufactures they all give different specs. so I,m unsure what size to install the motor is stock any suggestions . Thanks Jeff
