Inner tie-bar needed??? >
Old 11-05-2004 | 09:37 PM
daveo1
Default Inner tie-bar needed???
I have a 1999 29' Baja outlaw with twin 454's with Bravo 1's. The boat has an external imco tie rod on the drives. Do I need to keep the internal one on the tiller arms? I have relocated a few things on the transom and the inner bar is giving me hell. I have been told that some mfg's don't use an inner if the boat has an external. Please advise...
Old 11-05-2004 | 09:45 PM
pachangalpina's Avatar
Default Re: Inner tie-bar needed???
I have been told not to use the inner while using the outer because it may work at one trim setting and cause issues at others.
pachangalpina is offline
Old 11-06-2004 | 07:07 AM
Audiofn's Avatar
Charter Member #232
Since you have a good external tie bar then you are fine not to put the inner one back on.
Jon
Put your best foot forward!
Audiofn is offline
Old 11-06-2004 | 07:46 AM
Mbam's Avatar
Offshoreonly Advertiser
Does it have external steering? If so the inner is optional, if not the steering load for both drives winds up on the 1 gimbal & tiller with the PS actuator so it is not a good idea. The only problem with running both tie bars is stress on the gimbal ring / upper shaft / steering arms if the drives are not trimmed the same at all times.
Mbam is offline
prostock85
Fountain
8
05-22-2007 08:34 PM
MILD THUNDER
4
06-02-2005 03:17 PM
Scarab3DMC
04-27-2002 08:30 AM
