Trailer help
Old 11-10-2004 | 07:40 AM
Stormrider's Avatar
JC Performance Engines
Default Trailer help
I have a double axel trailer... recently overhauled.
I had it redone becuase a bearing had broke, and the forward port side wheel had broken off!
Yesterday was the 1st day w/ the boat on the trailer since the overhaul and while backing down into a 90 degree turn, again the front wheel on the inside of the turn seemed to be flexing on its horizontal axis.
Is this normal? or what could be the problem?
Stormrider is offline
Old 11-10-2004 | 07:56 AM
SeaRay Jim's Avatar
Default Re: Trailer help
Sounds like you had a spindle break the first time? It almost hard to mess up replacing a spindle and even the brake assembly if it has brakes on both axles, so depending on exactly what you mena by "flexing" it could be normal. The trailing axle (fring in the case of backing) will drag/scuff the wheel, especially the inside and may actualy make it look "tilted" which could be perceived as moving.
If you do a lot of those 90* turns it will put pressure on the spindle. Have a bearing come apart and you can quickly break a spindle in the right situation.
Best way to check is to get that wheel off the ground and check for movement. Shouldn't be any. If thee is, pull the wheel and hub and check the bearings.
SeaRay Jim is offline
PurpleStuff
2
06-21-2007 08:02 PM
Followmygut
2
05-13-2007 10:41 PM
Gene in NC
08-17-2006 09:56 PM
Poorsche
2
09-13-2005 07:30 AM
boot
11-22-2004 01:43 AM
